CH7466CE WiFi stopped working
ggb
Hi Community,
I have a CH7466CE router and recently the WiFi connection has been unstable, iOS devices either couldnt connect or needed to be rebooted to get on the WLAN/internet. Today the WiFi has stopped working completely - even the TP-Link range extender could not connect to the router. The WLAN is no longer visible in available networks.
The internet is still reachable via ethernet connection to the router.
Any ideas as to the potential problem and solution? The router has been rebooted several times.
Thanks in advance.
ERFD
Hello ggb,
a factory reset and a channel change did you try?
Best regards Fred
