WLAN-hotspot-Flat English
Luis28
Hello Vodafone Team,
I need your support since I cannot connect to WLAN-Hotspot-Flat
I have activated my account already and created different user names and paswords to access, however every time I try to connect to any hotspot it just wont let me do it. A screen pops up asking  to accept the terms and conditions and when I hit accpet I get directed to the same screen in which I have to provide an user and password, but this time it tells me that if I want to use WLAN i need to book that service
Kundennummer ***
Hotspot ID: UM-90:5c:44:43:06:f6
Hotspot ID: UM-90:5c:44:8d:e0:2e
Hotspot ID: UM-ac:22:05:bc:89:e9
Thanks for your help.
Edit: Customer number removed for data protection reasons. VF_Grit
R4mona
Hi Luis28,
please be so kind and do not write any private data (customer number, real name, address) publicly in the forum. Data protection is our highest priority.
So that I can help you, I need some more information from you. Please answer the following questions as detailed as possible:
- Is the hotspot activated in your online customer center?
- Have you already tried to set a new password?
- How do you try to connect via the Vodafone hotspot?
- Are you using the Hotspot app?
- Did you select "Surf as Homespot service participant" in the
  login screen?
- Did you use the user name of your online customer center
  login?
- Did you make sure that "Customer Portal Login" is selected in
   the drop-down box?
Kind regards
R4mona
