am
12.03.2021
14:43
- zuletzt bearbeitet am
12.03.2021
15:05
von
Mav1976
Hello, is it possible to switch the voicemail menu to English? I have changed my Customer Service menu, but it did not affect my voicemail menu.
Thank you.
*** @elsoybean, thread moved to Andere VF Services (other Vodafone services)! ***
am 12.03.2021 17:37
I transcribed it so that I could get it set up; in case anyone else needs to know what to do when you first set it up, it wants you to put in a PIN, followed by #, then confirm it with #. Then it will ask for your first and last name, and #, and again confirm with #. Then, you can press 1 to use the standard greeting, or 2 to record your own greeting. I only did 1, so not sure if there is more for a custom greeting, but after that my voicemail was set up and I could use this to navigate: https://www.vodafone.de/infofaxe/318.pdf
am 12.03.2021 17:37
am 16.03.2021 13:32
Hey elsoybean,
thanks for sharing your solution with us. I highlighted the solution and closed the thread.
Best regards & alle the best
Norman
