am 13.11.2021 06:23
Hello,
For 5 days in a row i had upload speed 0 and i could not connect to some sites, i tried everything, i restarted the router, i've reset it completely back to factory settings, i've changed the cables and it seems that today i can only enter just youtube and google, i can't connect to other sites,i can't connect or take a speed test. Even this message is written from another internet connection. I've tried network wizard from vodafone site and i got this message:
"There is a so-called return path disruption at your connection, which can restrict your Internet and telephone connection. If necessary, please let our technician check your connection. We will fix the problem as soon as possible. Thanks very much. There is currently no time to remedy the fault."
Can someone help ? I speak a little Deutsch thats why i write in english. I hope someone helps me.
Thank you !
am 18.11.2021 17:12
Hello Visovan,
does the problem still persist? If yes, please check the thread Alles rund um Störungsmeldungen and send the details that match your problem.
Kind regards,
am 19.11.2021 19:05
Hi Claudia,
After almost 2 weeks whitout working, now it's seems that internet it's working again. It's the second day in a row in that everything works fine. Thanks
am 22.11.2021 10:43
Hello Visovan,
as it works now I will close your thread.
Kind regards,
