Vodafone outage – reimbursement
JustAStrager
I am a Vodafon Kabel and Mobilfunk customer. There is a Vodafone Kabel outage (according to Netz-Assistant), and the Interten is compelety down all day long. As I am working from home, lack of the Interten causes a lot of problems to me. I have been using my mobile Hotspot to share the Interten from my mobile phone. Unfortunately, I have run out of available data volume. Is there any way Vodafone can reimburse my traffic, or provide any alternative solution to my problem?
Thank you.
Hello JustAStrager,
the data volume should arrive in a few minutes. Now I hope the outage will be solved soon as well.
Kind regards,
Hello JustAStrager,
we already have your data from a former thread. The outage is caused by a return path disrupter, the colleagues already work on that. Is the number ***285 the one you refer to? If yes, we can check if we can give you data volume, that would be 50GB for 16 days and replaces a refund. If you have a different mobile number please send it via PM and reply here again afterwards.
Kind regards
Hi @Claudia ,
Yes, it is the phone number.
Thank you!
Hello JustAStrager,
Kind regards,
