Router Wifi Turned Constant White On LED for Internet and Wifi but no Internet
georgewachira
Just recieved my vodafone router and activation code details, I went through the activation step and my router's LED lights for internet and wifi are constantly white but when I connect to the wifi there is no internet when I log into the router the connection status is as follows:Screenshot 2022-06-14 at 18.23.48-min.png
5 Antworten 5
natas666
after connecting the router (mta) 2 the system, normally the system notices that automatically and the installation process starts - upgrading the software, provisioning of internet- and telephone-services.
after a few minutes everything should be fine.
unfortunately sometimes this "plug & play" routine doesn't work - the system does not notice that new mta is connected.
in those cases the led is white, seems 2 be fine, but this shows only that your mta has connection 2 the system - it does not mean the provisioning of the services is done !
call the support - after trying a lot of "on - off - waiting a minute - on - off"
metal never dies
I already tried several times restarting the router and also did a reset but to no avail. Also called Vodafone tech support several times but since I dont know any german they refered me to the forum. I would be really greatful If I could get a technician to come by my place. Ive been surviving with prepaid sim data and its surelly not cheap
Martin59
Hi georgewachira,
I'll take a look at it.
Can you please answer me in advance in which state you live?
Best regards, Martin
Hi @Martin59
I live in state of Berlin.
Let me know if you need anything else
Martin59
Hi georgewachira,
please send me the name of the contract holder, the date of birth, the complete address and the customer number via PN .
Then leave a short info here and I'll take a look at it in detail.
