15.02.2022 12:21 - bearbeitet 15.02.2022 12:26
Hello,
Connection details
Problem description
Starting around Wednesday last week (09.02.2022) I started to observe internet connection problems. I noticed that my router randomly reboots by itself multiple times during the day without any clear reason. Changes in the status indicators on the front panel were further evidence of this.
After checking router logs I saw numerouse messages indicating some changes to WiFi configuration (see eventlogs file attached):
[info][WiFi][ Configuration Changed : Set Device.WiFi.AccessPoint.1.X_CISCO_COM_KickAssocDevices to true from CLIENTTOOL,old value is : false,result: Set successfully.]
Apparently, change to WiFI configuration forces router to reboot and as a result internet connection is lost for next 5 - 10 min. Also, I have WiFi disabled and I use only LAN ports, so it's not clear why does some change to WiFi configuration occurs at all.
After an investigation I tried to apply some solutions suggested here Vodafone Router and here Kabelmodem start mehrfach am Tag neu, but it helps only for a half a day. At some point the router reboots again, resets WiFi settings and the issue starts all over again.
Could you please help me to solve this problem?
Thank you!
am 15.02.2022 14:28
I apologize, I have made a type in router model name. The correct model is: Vodafone TG3442DE
am 16.02.2022 16:43
Today I tried to switch the station to Bridge mode and the issue is still there. Vodafone station reboots serveral times per hour and makes it impossible to work from home.
Could please someone help or give me any suggestion what could be done in such situation?
Thank you!
am 18.02.2022 15:04
Hi 1B4A3769,
sorry, that the connection does not work as ist should Let us have a look at it and we'll what's going on there. Please send me your name, address, day of birth and customer number by PN. Please also let me know here if you have sent the message.
Kind regards
