am 19.04.2022 09:02
Hello Vodafone,
I'm opening a new thread following the connection issue I had last year as I'm again experiencing disconection and packet loss every hour every day: https://forum.vodafone.de/t5/St%C3%B6rungsmeldungen-Internet-TV/Technicolor-VF-2-0-17-keeps-rebootin...
Here are the general informations:
Here is a pingplotter over 10 minutes:
I really would like this to be fixed as I cannot accept to have such disturbance every hour.
Thank you for your help,
am 19.04.2022 09:04
I even had trouble posting this new thread because of the connection instability
I hope we can quickly find a long term solution
Thank you
am 20.04.2022 08:23
Hello clems,
for a closer look send me the following informations in a private message:
full name
date of birth
address
customer number
Write a short reply here afterwards.
Best regards
Tina
am 21.04.2022 08:23
Hello Tina,
I've just sent you all the informations in private message.
am 22.04.2022 14:41
Hello clems,
thank you for your data. I assume the missing upstream channels and the bad signal is the reason for your disconnects. The other modems in your building have trouble with the signal as well, that's why I want to send you a technician. Can you give him access to the house installation? Please make sure that no one in your household is in quarantine when the technician visits. Is the mobile number ***371 your current one?
Kind regards,
am 22.04.2022 14:58
Hello Claudia,
Thank you for the follow-up. I am OK for a technician to come to the building and in my apartment to inspect the installation. When is someone available?
No one in my household is in quarantine and/or have been recently in contact with someone positive to covid-19.
Yes, this is the correct phone number.
Best regards,
am 23.04.2022 20:24
Hello clems,
I have created the order for the technician. You will then be called for an appointment.
I keep my fingers crossed that everything will work again afterwards.
Greetings Jana
am 08.05.2022 10:28
Hello,
If you have access to my internet connection data, you can probably see that the issue is not resolved.
To be honest, the technician did not even show up and just explained to me by phone that the issue comes from my building installation and therefore he cannot do much unfortunately.
But he also told me that for other clients with similar issues, using a Fritzbox is improving the situation. Since you cannot do anything else to improve the situation, is there a way to get a Fritzbox for free to check if it "solves" at least partially the issue?
Thank you for your help.
am 09.05.2022 11:56
Hi clems,
why didn´t you come up earlier? The technician wrote in his report, that you did not want him to come... peculiar.
For explanation, when the signal is very bad at your antenna socket, another box will receive the same bad signal and won´t improve this. So a Fritzbox doesn´t make it better.
We have to let this check at the building from a technician and yes he can check the values and adjust it. So do you agree if I send you a technician again?
Best regards, Manu
am 09.05.2022 19:56
Hello Manu,
Of course I agree to have someone that can actually solve this issue.
Thank you again for your help and sorry about the confusion here.
Best regards,
