am
17.01.2022
13:29
- zuletzt bearbeitet am
17.01.2022
19:13
von
Torsten
Hello,
My contract is *** and this is very slow for the past month. I face a large number of problems. Please have a look and let me know If you need further information.
Modem is Vodfone TG3442DE
I am using a Cable with a modem
I am living in Moabit Berlin.
Looking forward to your response.
Thanks,
Edit: @iamgurjit removed customer number for data protection reasons. Please don't post personal data open.
am 17.01.2022 19:15
Please answer the questions from this thread so that it is easier to narrow down in advance. Incidentally, screenshots of your channel values are much easier to read than copy and paste the values.
It would also make sense to run speed tests and post the results.
am 17.01.2022 19:31
am 19.01.2022 10:41
Hi iamgurjit,
the signal is good, but there is a high load some times. Would you please give us some speedtests through a wired connection to the modem?
Kind regards
am 17.03.2022 09:54
Hi Vodafone, This is the worst internet connection I have had in my entire life. It is giving me huge problems. I am unable to work since yesterday due to a lot of interruptions in my connection,
The speed Is very poor these days, please give me a solution asap. I am available for a call to explain in detail.
Looking forward to your urgent response.
Thanks,
Gurjit Singh
am 18.03.2022 08:43
Hello iamgurjit,
sorry that your connection is not working as it should.
The reason for this is an interference signal that is active in your catchment area.
The technicians have already narrowed it down to a specific line.
At the moment, appointments are being made so that the objects connected to it can be checked and the interferer can be eliminated.
I have created an order for you and assigned it to the network fault so that you will be informed about the completion.
Best regards, Martin
