Internet LED on router is blinking red and no intermet
Owais
Hello, sorry for English, my German is not good.
Since last night, the internet LED on my router is continuously blinking red and there's no internet.
I have tried the following:
  • Disconnect router for 3 minutes and connect to power again
  • Reset router
  • Check if cables were loose.
None of them seemed to work. The internet working completely fine before.
If needed I can provide logs from the router.
Appreciate any help,
Thanks,
Owais
R4mona
Hey Owais,
Thanks for your update. Smiley (fröhlich)
We are really happy that your internet is working again without any problems. Please be so kind and mark a post as a solution. Then we put a lock on it.
If you have any questions again, feel free to create a new post.
Kind regards
R4mona
4 Antworten 4
Moni_GK
Hello Owais,
sorry that the connection does not work. I'll be happy to take a look at it.
Please send me a PN with your customer data (name, address, customer number and date of birth).
Then please contact me again here, if you have sent me the data.
Best regards
Moni
Hi @Moni_GK
Thanks for the reply, I have sent you the PN with the requested details.
Owais
Hi @Moni_GK
Just wanted to update you, I just checked and the internet is back again.
Thank you for your service!
R4mona
Hey Owais,
Kind regards
R4mona
