am 23.11.2021 12:58
am 25.11.2021 19:04
Hello Nina,
nice to see you. Please answer the following questions:
In which federal state do you live? Please also send the postcode
Which modem/router do you use? (e.g. Hitron)
Are you using a rental device from us or do you have your own device?
Which error occurs? (Speed too low; Packetloss) Send also screenshots of speed tests (with date and time) and tracerts/ ping plotter measurements in case of packetloss or ping problems.
How is your end device connected to the modem? (LAN; WLAN; additional router; PowerLAN)
Which browser do you normally use? (e.g. Firefox)
Which operating system do you have on your computer? (e.g. Windows)
Beginning and period of the problem (e.g. since the beginning of April; only in the evening)
Upload a screenshot of the signal values. You can find them in the user interface of your cable router via 192.168.0.1 or via 192.168.178.1 for the Fritzbox.
What measures were taken by the fault hotline (available at 0800-5266625 for Vodafone Kabel Deutschland or 0221/46619100 for Vodafone West)?
Best regards
Tina
Translated with www.DeepL.com/Translator (free version)
Tina
