am 20.09.2021 09:35
Hello ,
I changed my device to Fritzbox because the former vodafone station was having issues with slowness and disconnecting as well and customer service said fritzbox is better . Now since 2 months the device restarts by itself every now and then . can you please take a look and tell me what is wrong .
thank you
am 21.09.2021 12:44
Hello bukolaj,
please answer the following questions from the article All about incident reports.
Please also write in which federal state you live.
Then we know what kind of contract you have and how you use your connection.
Many greetings
Jana
am 28.09.2021 11:33
am 29.09.2021 16:10
Hello bukolaj,
please send me the name of the contract holder, date of birth, full address and customer number via PN .
After that, please leave a feedback here, then I'll be happy to take a look at the connection.
Best regards, Martin
am 30.09.2021 09:35
Hello Martin ,
I have sent the details via PN
am 04.10.2021 14:09
Hello bukolaj,
I can not read the values of the box at all.
A technician should take a look at it on site. Would that be okay for you?
Will the colleague come with you to the house installation? The cause seems to be in our area of responsibility. In this case, the service is free of charge for you. If the technician does not find anyone at the agreed time, if there is a fault in his own cabling between the router and the antenna socket, or if he is unable to gain access, we will charge 99.50 € for the service.
Under which phone number can the colleague make an appointment with you?
Due to the current developments we have to take certain precautions. Therefore we need to know if there are any symptoms in your household that could be related to Covid-19. Of course we don't want to offend you, but on the other hand we don't want to endanger more people unnecessarily.
Greetings Moni
am 04.10.2021 23:45
Hello ,
I am not sure i understand your message .
Under what circumstance will I be charged ? I though vodafone should bear the cost of a customer not enjoying the service paid for ? please advise me what you mean
am 06.10.2021 15:43
Hello bukolaj,
You will incur costs if your cable from the socket to the router is broken, you are not there for the appointment or the technician cannot get access to the house system. These are all factors that we cannot influence.
Greetings Moni
am 18.10.2021 10:27
Hi Moni ,
Is there any reason why you cant connect to the device remotely and run some checks ?
am 20.10.2021 17:46
Hello bukolaj,
now I see the modem signal. Some of them are out of range, the other modems in the building don't have a problem there. Did you replace the coaxial cable already? If yes there is not much else you can do. Shall we send the technician then? For that we still need the phone number, the information for Covid-19 and the access to the house installation.
Kind regards
