Tp-Link Router
asad4
Forum-Checker
Forum-Checker
I am trying to use Tplink W9960v DSL Modem router for DSL instead of frtizbox.
Configuration is completed, but most of the websites are not accessible(mostly google and facebook services are accessible) all the other websites are not accessible on mobile and pc both.
RobertP
if you don't get an IPv4 address under Advanced > Status, but you do get an IPv6 address, you have a DS-Lite connection
TP-Link howto i found is only in german:
https://www.tp-link.com/de/support/faq/2750/
2 Antworten 2
RobertP
NitroOs
I had the same problem with DS-Lite connection and my TP-Link Archer VR2100v after Vodafone changed my internet tariff. The instructions on upper link helped me to make the IPV4 internet sites to work again.
Here is the Internet IP configuration that helped me:
hope it helps someone.
