am 06.07.2021 10:26
Hello,
This morning our router started reporting DSL errors. Gone via support bot and even factory reset it. Still router says that no DSL and cable in first 200 meters is fine.
Callback on last step failed two times. Can you please help and check whats up?
am 08.07.2021 17:49
Hi vimutter1,
sorry for my late answere. I've checked your landline. I got the error message that you're still useing the wrong login data.
Please set up the router with the new modem installationcode. I've sent you the new one via sms.
Let me know if it works.
Best regards
Norman
am 07.07.2021 10:12
Hi vimutter1,
i'm sorry that your landline is not working.
I'll check the line. Please send me a private message with your customer & cellphone number.
Will get back to you asap.
Best regards
Norman
07.07.2021 10:50 - bearbeitet 07.07.2021 10:51
am 08.07.2021 11:54
Hi @Norman
Any updates? We need internet for work, but still have to use mobile as replacement.
It's 3rd day without any DSL internet.
I cannot also open ticket at customer portal, this new wizard shows me error on the last step after 3-4 attempts.
am 08.07.2021 17:49
Hi vimutter1,
Best regards
Norman
