DSL not working/ no internet
Thomas8881
Dsl led blinking and no internet since from the morning.
2 Antworten 2
Thomas8881
The FRITZ!Box's "Power" LED flashes continuously.
The FRITZ!Box does not establish a DSL connection.
Jens-K
Hi Thomas8881,
did you check here if there is known issue in your area? http://www.vod.af/Netz-Assistent-DSL
Did you check all cables and restarted the modem?
Which modem do you use?
Regards,
Jens
