Accessing my home server
Andrija
Hello, since yesterday I am unable to access the server that install on my local network.
The server is working locally but I can not access it outside of the local network. If i disconnect from my local network and try to access it, then it works normally. Also, others have normal access.
I tried rebooting the router and the factory restart but no success. It was working normally 2 days ago and now something happened but I am not sure what because I didn't do anything out of the ordeneri.
I hope someone can help me with this problem,
Tnx, Andrija
2 Antworten 2
HeikeF
Hi Adrijana,
does ist work now?
If not please try this .
Better?
Best regards
Heike
Hi, thanks for your response but I don't have a problem with the connection, my internet works fine just I cant connect back to my public IP address to access my server. The server works fine and I know because other people can connect to it.
