am 16.09.2021 14:59
I purchased a Vodafone SIM card, with CallYa Allnet Flat M (3gb data for 9.99e) I used the data over a few days, and relaised this tarriff is insufficient for my needs, I changed to a new tarrif, Allnet Flat L... I then added 50e credit to my Vodafone account... but I somehow cant figure out for the activate the new tarrif immediately..... the website is telling me it wont actaivate until 28 days after my initail tariff was activated??
am 16.09.2021 15:52
Hi @simonok,
That's right. The new tariff (Allnet Flat L) will be active when the other tariff (Allent Flat M) ends normally.
If you need more data volume then you can buy additional data packages as an option. But be aware that the options have a duration of 28 days too.
For example. If your current tariff is active til 21.09.21 then your change (Allnet Flat L) starts on 22.09.21.
am 16.09.2021 15:52
Hi @simonok,
am 16.09.2021 15:55
