CallYa Prepaid top-up: Multiple charges
jonoave25
I wanted to top up my CallYa balance with €20 euros. So I did the usual transaction through MeinVodafone and after clicking confirm, the loading status seems to be taking a long time.
Then I got several notifcations from my bank app: I was charged €20 four times in a row! A few moments later the balance is reflected in my CallYa balance, but clearly I don't want to top up that much.
Could you please cancel the last 3 transations/refund €60 back to my card?
Thanks.
MichaM
Sorry about this issue while topping up your balance.
Did you already check with the CallYa helpline? 0172-2290 229.
Else, you can send me a private message, so I will look for a solution.
Please include
* your prepaid number
* a number for calling you back, if different from your prepaid number
* the link your thread here
Regards
Micha
2 Antworten 2
MichaM
Please include
Regards
Micha
Hi MichaM,
Thanks for your reply. I was not aware of the CallYa helpline. I contacted tem and they said they will refund me, so fingers crossed.
Thanks and Merry Christmas
