Hilfsangebote außerhalb der Community
  • Jetzt mit Tobi chatten Chat Jetzt mit TOBi chatten
  • Nutze unsere Hile bei Störung. Störung? Nutz unsere Hilfe bei Störung!
  • Entedecke unsere digitalen Lösungen und nutze sie Mehr? Entdecke unsere digitalen Lösungen und nutz sie!
Unitymedia user stable connection problems
bosulol
My internet connection speedtested shows 100mbit instead of 250. Since three weeks I'm not able to go for my bills "Access Manager for Web" from unitymedia after pressing "Meinerechner", also my internet connection since few weeks started to be really slower - connection is not stable. (latency jumps m / s) It is not possible to play any of the online games because of disconnections. I'm not using WIFI, only straight cable / ethernet connection to PC. It is not problem from my side because internet connection is ok between 7:00 AM and 1:00 PM, after that as spoken above.
NRW
9 Antworten 9
bosulol
12:33 1:33 PM 250mbps
15:06 3:06 PM 100mbps
Can anyone help ???
MariaK
Hello bosulol,
can you please give us some more information about your connection and configuration? Here you will find a few points that we need from you: Link
Thank you very much and greetings,
Maria
    - Internet + Telephone 250
    - Router designed by Vodafone (serial number:  A574D29CJ704128 )
    - N/A as above
  • Welcher Fehler tritt auf? (Geschwindigkeit zu gering; Packetloss) Schick dazu auch Screenshots von Speedtests (mit Datum und Uhrzeit) und Tracerts/ Pingplotter-Messungen bei Packetloss oder Ping-Problemen
    - Speed got lowered from 250mbit to 100mbit, sometimes at night its 250mbit but since weeks 3/4 of time it is 100mbit.
    I took also screenshot when I was doing something at night and it was working as u can see below.
    - Packet loss for sure it is unable to play (fast-paced) online games.
    - Since 3 weeks I'm working from home so video conversations/streaming were not that nice.
    - When I started with Vodafone Internet I've had around 20-25ms now it is 29-40ms with 0.5s drops to 200ms.
    - Kabel->Router->Ethernet->PC
    - I use pretty much every browser available, most of the time Google Chrome, Firefox and Edge.
    - Windows 10 Pro (20H2 - 19042.928)
    Since the beginning of April but I realised with the problem for sure around 12th of April.
  • Welche Maßnahmen wurden durch die Störungshotline (erreichbar unter 0800-5266625) durchgeführt?
    - I haven't made a call because I'm not able to speak in Deutsch.
  • In welchem Bundesland wohnst Du?
    - NRW
    + I'm not able to check "Meine rechnungen" after logging to vodafone services.
Since April 13th, 2021 you have to use MeinVodafone to log into the online customer center, everything else no longer works. The login data remains the same, however, if you already have an account for MeinVodafone, you can simply add the contract as a Unitymedia contract with the customer number and the date of birth of the contract holder. Alternatively, use the suffix -vf after the user name.
Ida
Hi bosulol
Send me a PM:
full name
full addresse
date of birth
customer number
Please write here again as soon as the PM ist out.
Best regards
Ida
bosulol
Private message has been sent.
R4mona
Hi bosulol,
I have just replied to your message.
Kind regards
R4mona
Private message sent.
Ida
Hi bosulol
Since your device has been listed as online for more than 21 days, I have now rebooted. Please test the connection again via LAN. The reboot may take 10-15 minutes.
Best regards
Ida
