Cable Internet
Mina-dhg
Hello,
I ordered a cable internet from Vodafone after checking the availability of cable internet in my apartment. My contract started on February 1st. Unfortunately, the internet did not work. I called the Vodafone hotline and they sent me a technician from solution30. The technician said a cable had to be laid from the basement to the 5th floor and needed the property management permission. I would like to know how I can cancel the contract if the property management does not allow it and the 14-day return period expires.
Ich habe Kabelinternet bei Vodafone bestellt, nachdem ich die Verfügbarkeit von Kabelinternet in meiner Wohnung geprüft hatte. Mein Vertrag begann am 1. Februar. Leider funktionierte das Internet nicht. Ich rief die Vodafone-Hotline an, und man schickte mir einen Techniker von solution30. Der Techniker sagte, dass ein Kabel vom Keller bis in den 5. Stock verlegt werden muss und er dafür die Erlaubnis der Hausverwaltung braucht. Ich würde gerne wissen, wie ich den Vertrag kündigen kann, wenn die Hausverwaltung dies nicht erlaubt und die 14-tägige Rückgabefrist abläuft.
Nancy
Hello Mina-dhg,
if your property management does not agree to the installation, we will receive a corresponding response from the technician and he will cancel the order.
Best regards
Nancy
Nancy
Hello Mina-dhg,
Best regards
Nancy
Hello Nancy,
Thank you for your reply. I am still waiting for property management response.
Today I received a new contract and a new router from Vodafone for Internet. I don't know who ordered it! Could you please check what it is and cancel it as soon as possible.
Nancy
Hello Mina-dhg,
in your other thread, you were correctly advised to cancel the unwanted contract. You will find the cancellation form with the order confirmation.
Best regards
Nancy
