My TV Box does not power on any more
HaoY
I was advised to post a message here for help in English. My Giga TV box could not be powered on for a few weeks already. I checked all connections, they all seem to be good. I suspect the box might be defective for some reason. Please kindly advise what I should do.
Thank you!
BR, Hao
Martin59
Hello HaoY,
thank you very much for your information and we are happy that it works again.
If your request is solved, please mark a solution here and we will close the contribution afterwards.
Many greetings, Martin
Martin59
Hello HaoY,
which TV Box do you use? A receiver with smartcard, the Giga 4K Box, the small Netbox or another receiver?
Best regards, Martin
It is a GigaTV 4k Box.
Sorry that I just noticed that there is an ON/OFF button on the back side of the box. I never turned the box off, but there was probably a power cut and then I did not notice this button while checking the connections. The box is working now. Sorry for the mistake.
Thank you!
BR, Hao
Martin59
Hello HaoY,
