Error SA005
DanielPineda
I found there are different opinions to fix this error.
I disconnect the Giga TV Box 2 for 30 minutes and still not working
Someone can explain what is really needed to can watch the TV?
Thanks
best regards
Edit: @DanielPineda  Moved in the right board. Best regards Kurtler
Jens
Hello Daniel,
did you connect the box with a internet connection?
Also say where you come from (zip code).
Regards
Jens
