Vodafone station LED schaltet sich aus
IlyesOu
Hello, I have had the Vodafone station for 7 months now and have had no complaints. However, last month the LED "Internet" turned off, but everything works fine, only the LED has turned off. I turned the device off, but the LED stayed off and the internet works fine, so I just ignored it. Today the same thing happened with the LED "PHONE". It turns off, but the phone works fine.
What's going on? Are the LEDs built into the device so cheap that they die after 6 months?
2 Antworten 2
rkagan
Same here. My station (make Technicolor CGA6444VF) is 2yr old, and by now it has no front panel LEDs lit, not even Power, but works ok otherwise.
I ignore it for now as I can see the status even better via the web control panel, but it makes me wonder about the hardware quality indeed
Thanks for the reply!
That's exactly the model number I have, hopefully my other LEDs survive 🤣(only POWER and WIFI are left now).
Kind regards
