Chat Jetzt mit TOBi chatten
Störung? Nutz unsere Hilfe bei Störung!
Mehr? Entdecke unsere digitalen Lösungen und nutz sie!
Not able to enable port forwarding in Fritz box 6600
Rajkumar
Recently, I have upgraded to rental Fritzbox 6600 from Vodafone
to use the Portforwarding function, to get access to my NAS,
after enabling the port-forwarding, nothing happens,
still, the network is blocked outside the home network, and LAN speed is slower than the previously used Vodafone station cable router
need help please support enable or cancel my additional booked option "HomeBox Fritz!Box 6660"
thanks
Raj
according to your screenshot IPv6 is enabled
but you have to use the NAS IPv6 address from external not the one from the Fritzbox
in general there is no port forwarding with IPv6, as already mentioned IPv6 works with port sharing
15 Antworten 15
RobertP
in which federal state do you live and what kind of contract do you have?
I live in Nuremberg, Bavaria
My contract "Red Internet & Phone 250 Cable"
you don't have dual stack and I think it is not possible to activate it in Bavaria
you need to set up IPv6 port sharing instead
checked with https://ipv6-test.com/
it shows unsupported do we have any other options?
ipv6 testipv6 test
is IPv6 activated on your 6660 an on the device from where you have tested connectivity?
Hi Robert
thanks for coming back,
still, it's not resolved yet in my router, and I can't able to see my IPv6 address on my router
http://www.test-ipv6.com/http://www.test-ipv6.com/Fritzbox statusFritzbox statustechnical information of the networktechnical information of the network
please help to solve this issue
thanks
Raj
seems IPv6 is not enabled on the client PC
which OS are you using on the client?
Hi Robert,
I'm using windows 10,  and my NAS uses Debian (OpenMediaVault),
thanks
Raj
ssh into your NAS and type in
ip a
