am 30.07.2023 13:09
Hi.
I moved to another flat and the added plug for modem no longer fits the socket. There is some metal thing on all the sockets on the flat that doesn't let it in.
Could you please advise what I shall do?
30.07.2023 13:27 - bearbeitet 30.07.2023 13:28
take the middle Connector , and for TV the left side! At the wall side!
am 30.07.2023 14:36
Oh, so I just need to plug the cable directly into the socket, with no box needed.
Thank you so much for your quick answer. It all worked!
am 30.07.2023 14:44
Since the problem has been solved, I am closing the thread.
Best regards Kurt
