Very slow internet connection at weekends and evenings
ergin
I have Red Internet & Phone 100 Cable and using KabelBox CH7466CE. I am connected via ethernet but also slow connection happens with WLAN as well.
Internet is usually good in the mornings, after midnight. But too slow at weekends, evenings. I have this problem for couple of months but unfortunately nothing changed or improved yet.
Also speed is very unstable and reliable. In the same time frame, i tried 10 mins network speed tests. Isee both 90 Mbit, 5Mbit, 8Mbit download speeds in order.
Hello ergin,
the planned date for the expansion is at the beginning of the next quarter. I made the task for the technician so he can fix the signal problem and hopefully improve the connection.
Kind regards
8 Antworten 8
ergin
Will anybody answer and help or also don't you support English help like call hotline?
Hello ergin,
we do give support in English, but depending on how many threads we get it might take some time. I'd like to have a look at your modem, so please send me a PM with your full address, the date of birth from the contract owner and the customer number. Leave a short reply here in this thread after you sent the PM.
Kind regards,
Hey Claudia,
Thanks a lot for help. I sent PM.
Hello ergin,
the reason for the low bandwidth on evenings and weekends is a high net utilisation at those times. There are already plans to expand the net and reduce the utilisation, you will get an e-mail when they are finished. In addition, some of your downstreams have a bad signal. If a technician corrects them it might have a positive effect on your connection. Do you want to try that? If so, is the number that ends on ***866 still correct?
Kind regards,
Hey Claudia,
Thanks for investigation. Do you know when it planned and how long it will take? Because somedays are so difficult to use internet. Yes, my number phone is that one and i can try that.
Thanks,
Ergin
Hello ergin,
Kind regards
Hey Claudia,
Today technician helped me to fix some problem with my connection. Looks like i have better connection and more stable internet. There is a great improvement when i compare with my last connection and usages.
Thanks a lot for your help,
Ergin
Manu
Hi ergin,
I hope you're happy now.
I'll finish the article here and if something should happen again, feel free to contact us again.
Best Regards, Manu
