An error occured! templates/dsl-kabel/_help.html (No such file or directory) java.io.FileNotFoundException: templates/dsl-kabel/_help.html (No such file or directory) at java.base/java.io.FileInputStream.open0(Native Method) at java.base/java.io.FileInputStream.open(FileInputStream.java:213) at java.base/java.io.FileInputStream.(FileInputStream.java:152) at clojure.java.io$fn__11655.invokeStatic(io.clj:232) at clojure.java.io$fn__11655.invoke(io.clj:232) at clojure.java.io$fn__11607$G__11561__11614.invoke(io.clj:72) at clojure.java.io$fn__11629.invokeStatic(io.clj:168) at clojure.java.io$fn__11629.invoke(io.clj:168) at clojure.java.io$fn__11568$G__11557__11575.invoke(io.clj:72) at clojure.java.io$reader.invokeStatic(io.clj:105) at clojure.java.io$reader.doInvoke(io.clj:89) at clojure.lang.RestFn.invoke(RestFn.java:413) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.RestFn.applyTo(RestFn.java:135) at clojure.core$apply.invokeStatic(core.clj:669) at clojure.core$slurp.invokeStatic(core.clj:7089) at clojure.core$slurp.doInvoke(core.clj:7089) at clojure.lang.RestFn.invoke(RestFn.java:413) at sc.vodafone.website.pages.may22.templates$render.invokeStatic(templates.clj:10) at sc.vodafone.website.pages.may22.templates$render.invoke(templates.clj:6) at sc.vodafone.website.nav$render.invokeStatic(nav.clj:118) at sc.vodafone.website.nav$render.invoke(nav.clj:106) at sc.vodafone.website.html_export$nav_page.invokeStatic(html_export.clj:29) at sc.vodafone.website.html_export$nav_page.invoke(html_export.clj:25) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.AFn.applyTo(AFn.java:144) at clojure.core$apply.invokeStatic(core.clj:667) at clojure.core$apply.invoke(core.clj:662) at shadow.server.http.core$call_handler.invokeStatic(core.clj:161) at shadow.server.http.core$call_handler.invoke(core.clj:158) at sc.vodafone.website.html_export$http_root.invokeStatic(html_export.clj:52) at sc.vodafone.website.html_export$http_root.invoke(html_export.clj:50) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.AFn.applyTo(AFn.java:144) at clojure.core$apply.invokeStatic(core.clj:667) at clojure.core$apply.invoke(core.clj:662) at shadow.server.http.core$call_handler.invokeStatic(core.clj:161) at shadow.server.http.core$call_handler.invoke(core.clj:158) at sc.vodafone.website$root.invokeStatic(website.clj:656) at sc.vodafone.website$root.invoke(website.clj:650) at shadow.server.http.core$do_request.invokeStatic(core.clj:840) at shadow.server.http.core$do_request.invoke(core.clj:836) at shadow.server.http.core$do_ring.invokeStatic(core.clj:858) at shadow.server.http.core$do_ring.invoke(core.clj:844) at sc.vodafone.system$get_ring_handler$fn__28838.invoke(system.clj:420) at ring.middleware.file$wrap_file$fn__28579.invoke(file.clj:50) at ring.middleware.content_type$wrap_content_type$fn__28613.invoke(content_type.clj:34) at org.httpkit.server.HttpHandler.run(RingHandler.java:91) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:572) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:317) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) at java.base/java.lang.Thread.run(Thread.java:1583)
My internet is not working
GenesisMK
My Cable internet is not working since last night.
I have tried multiple resets and reboots.
I have a Vodafone TG3442DE cable modem with an integrated router and telephony gateway.
The power and wifi lights are on and the Internet light is red.
I tried calling Customer Service but the only speak in German and my German isn't that good so I didn't know if he got my issue.
I don't know how to solve this. I live in Berlin- Wilmersdorf 10719
Sahil
11 Antworten 11
Wallace
Hi Sahil,
I like to watch the line. Send me your customer data (name, address, customer number, birthday) in a private message and let me know here that you have transmitted the data.
VG Wallace
Hi Wallace,
My line started working after abkut 30 hours I think the customer service person I spoke with in broken German got my problem although I didn't get a ticket or a complaint number.
Thank you for your response
Wallace
Does the connection work as it should?
Reagrds
Wallace
Hi Wallace I have replied to you  on the Personal message
It often happens that the internet goes down for hours but since support doesn't get back immedeately, it resolves itself in a few hours and everythng is fine.
By the time an engineer enquires there is no fault. For example right now it is not working. I will raise a ticket and an engineer will contact me tomorrow. By then it would be working fine and even for a few weeks it will work fine. I had no issues since my last message and it suddenly stopped working again.
The connection breaks for no reason but I cannot point out when. Even if you monitor the connecton for te next 3 days it will fine but then will break after another 10 days.
I lose a day every 10 days or so in the middle of a working day and that is really poor service.
Sahil
Wallace
I like to look at the line. I need your name, full address and date of birth in a private message. Get back to me here when you have sent me the data.
Regards
Wallace
Hi Wallace,
I have sent you the information in a Private Message
Sahil
Wallace
I can't find anything that could explain the failures. Is it okay if I swap the router?
Regards
Wallace
Hi wallace,
Thank you for looking into this. What is the downtime in the event of a swapped router.
I cannot afford to lose 2-3 daysbof work becuase of such changes as we are in a very critical stages of a project at work.
During the router swap how long will the internet be down ?
I  would rather not have issues and wait 3 days till an engineer shows up again
Sahil
Wallace
Hi Sahil,
You get the router by parcel service and exchange it yourself. The downtime will only be a few minutes. Can I arrange the swap?
Regards
Wallace
