Not able to connect to vodafone hotspot
Neharika
Recently, I am not able to connect to vodafone hotspot at Thomas Münzter Platz, Dresden. Can you please check that it works?
Thanks
7 Antworten 7
Moni_GK
Hello, Neharika,
is it just the hotspot that doesn't work or all of them? Which Hotspot ID is affected?
Best regards
Moni
Hi Moni,
Thanks for the reply.
I don't know exactly which one I was connecting to, as there are many in that area
One example is this one: HH-4-4654770.
Mostly I don't see the vodafone hotspot, homespot option in WiFi connections. When I see it, I am not to connect to it. The internet doesn't work
Hello Neharika,
the router from the ID you sent is offline, so maybe the owner unplugged it. In that case the Homespot isn't available as well.
Kind regards,
So what is the solution for that? Is it possible to contact the owner and get it restarted? I am paying for this homespot service, so of course I would like to use it.
ERFD
Hello, Neharika,
no, there's nothing we can do. If and how long the router is active is decided by the owner only. Unfortunately, there is nothing we can do.
Best regards Fred
I would like to cancel my hotspot contract. Please let me know the procedure for the same.
pRo-Marco
Hi Neharika,
you can cancel your contrakt through: https://kabel.vodafone.de/kontakt
Kind regards
