22.11.2019 13:01 - bearbeitet 22.11.2019 13:05
I had placed an order for a phone with a new contract over a portal on 6/11/2019 (I had also opted for number portability service also), but unfortunately I had done mistake while filling in the details. I was asked from the portal to place a new order as the old order was canceled because of mismatch in data.
I placed a new order on 07/11/2019 and everything went well, I got my new phone, sim card and new contract for this order. I waited for a week for the number to be ported to this new contract it didn’t happened, then I contacted to Vodafone and then I was told that I have two contracts running in my name one from 06/11/2019 and 07/11/2019 and the number was ported to the order from 06/11/2019.
I have been trying to get thing solved for past 4 to 5 days but I am not getting any positive or concrete reply. Vodafone also booked two time the money for these two contracts. The portal told me that they had received the cancellation confirmation on 15/11/2019 for the order from 06/11/2019 but I don’t know why is the contract still running.
Can you please help me with the situation.
Thanks, Tushar
am 25.11.2019 16:05
Hi tushar,
Welcome to the Vodafone Community ![]()
Sorry to hear that your new contract got off to a bad start. Hopefully, it can be amended.
Please help me get this straight:
>>I was asked from the portal to place a new order as the old order was canceled because of mismatch in data. <<
I understand that you ordered both contracts not in the Vodafone online store but in another store.
Is that so?
>> the number was ported to the order from 06/11/2019. <<
This means that once the contract from 06/11/2019 is cancelled, the ported number will return to the previous network provider.
You can have it ported again, this time to the contract from 07/11/2019, if you order the porting no later than 90 days after your contract with the previous provider has ended.
To have this sorted out, please send me a private message.
Regards
Micha
am 25.11.2019 11:06
Hello,
Is there no one who can help me with this problem.?
Thanks, Tushar
am 25.11.2019 16:05
Hi tushar,
Is that so?
Regards
Micha
