Wlan ohne warten ( englisch )
Abdullah1
Hi
I have a Dsl Internet contact with Vodafone 25 mb .. and I ordered a wlan ohne warten ..
To use it till they will install my internet connection
The problem is I tried to register the sim card ( because its not working without a registration ) but always I am having an unknown error and a massage tell me ( try it again later )
I looked into the forum questions and I found that there is actually this kind of problem and some people asked about it .. but I didn't found a solution or an answer ..
So I hope that someone from the tec team can answer me or help me how I will get my sim card registered to be able to use the Internet
4 Antworten 4
MichaM
Hi Abdullah1,
Thank you for joining the Vodafone Community.Smiley (fröhlich)
To register your WoW SIM, this is the registration site .
Did you try there?
If this didn't work please send me a personal message with a few details, so I can check what went wrong.
Regards
Michael
Abdullah1
Okey I tried .. but nothing worked ..
I send a private message with a personal details
Thanx
Hi Abdullah,
it should work now.
Please re-start your router and check.
Regards,
Michael
Hi Abdullah,
Thanks for your feedback via private message.
Your WoW service is up and running now. Smiley (fröhlich)
I'll close this chat.
Regards,
Michael
