am 08.08.2018 11:57
Hello Support,
We recently received a letter from our landlord (Vonovia) that they will cancel all Vodafone Kabel connections to all of their apartments across Germany on the 3rd of September. After this notice, we called Vodafone support and arranged a switch from Kabel to DSL on the same date.
A month later, Vonovia sent another letter saying that the cancellation will be delayed till the 3rd of December. On my Vodafone webpage, I can now see: Ihr Produkt wurde gekündigt zum:03.12.2018
Let alone the fact that Vonovia can have a direct impact on my personal account (which I don't understand...), I want to make sure that that there is no overlap between our Kabel and DSL contracts.
Is it possible that someone changes the cancellation date of the Kabel product to match the start date of the DSL contract?
I can send you all related information on a PM.
Thanks
am 08.08.2018 16:16
Hello,
because we do not know when the DSL contract starts, we cannot adjust the date exactly. But according to your statement, this fits at the moment (03.12.2018).
Regards
Grit
am 08.08.2018 17:24
Hello Grit,
We have already scheduled an appointment with a technician for the DSL installation on the 3rd of September. This is when I would like the Kabel to be cancelled.
The move to the 3rd of December from Vonovia happenned after arranging the appointment. Vodafone should be aware of that and not alter the switch date of 3rd of September.
I can give you my customer id so that you take a look.
Thanks
Ioannis
am 08.08.2018 20:04
Hello Ioannis,
only the message from you is not enough. To move the termination forward, we need an official letter from your new provider stating the leap day. Did you get this?
Regards
Grit
am 08.08.2018 23:37
Grit,
I will not change providers. The DSL connection is with Vodafone as well.
I want to switch from Kabel Vodafone to DSL Vodafone because I was forced by my landlord...
We already talked about that on the phone with a Vodafone customer support representative and then suddenly the original cancellation date from 3rd of September became 3rd of December without taking into account that we already agreed that I will move to DSL Vodafone.
I just want the DSL Vodafone to start the same date as the Kabel Vodafone finishes. This is what we discussed on the phone with your colleague.
Thanks
am 09.08.2018 14:24
Hello syra_muc_de,
unfortunately the leap day cannot be marked exactly. First of all it is important that the cable contract is not terminated too early, so that you are not left without a connection. As soon as the connection is switched, you register and we adjust the termination. This can also be done retroactively.
Don't worry, we'll figure it out.
Regards
Grit
am 09.08.2018 14:39
Thanks Grit,
I'll then write to you when the switch to DSL will have taken place.
Best regards
Ioannis
