am 02.12.2018 19:16
Hello,
I have kabel internet 200, but since couple of weeks I noticed the speed is slower a bit. When I tested it using the internet test website I had a maximum of 100 Mbps for the download speed. I tried the test couple of times in different days with the same result.
Can you fix the problem so I can optain my normal internet speed?
Thanks,
am 31.12.2018 12:11
Hello Ahmad-Safwat,
okay, the network card itself isn't the problem. Is it possible that you changed the settings to an limitation of 100 MBit/s? Could you try another cable that is suitable for the speed? Is there another device between the router and the PC?
Kind regards
am 16.12.2018 15:54
Hello,
Any hope that someone can help me in my issue?
Thanks,
am 19.12.2018 21:13
Hello Ahmad-Safwat,
did you have a 1Gbps ethernet connection between the cablerouter and your pc?
Regards
Jens
am 20.12.2018 12:32
Hello Jens,
Of course. I tried the test multiple times with no one on the internet with ethernet cable. I already got the 200 Mbps before. But now it seems there is a problem that max the speed to 90 Mbps only
am 27.12.2018 08:57
Hi Ahmad-Safwat,
is your ethernet connection at all the time? I can't see any connection now at the router.
Typical are the 90Mbps for only 100Mbps connection and not a 1Gbps.
Regards
Jens
am 27.12.2018 10:39
Hi Jens,
Yes, some devices connected wireless and 2 devices connected with ethernet. I made the tests from the computer connected with ethernet.. i am not using my computer now thats why u dont see a connected device. But i have my computer PC always connected with ethernet. And With the same computer and with the same ethernet cable i got before my 200 mbps normally. I didnt change anything. And now the speed dropped to half.
Thanks,
Ahmad
am 29.12.2018 11:39
Hallo Ahmad-Safwat,
I have checked the connection and the analysis has shown that your network card is not suitable for higher bandwidths than 100 MBit/s.
Which network card is installed in your computer?
Best Regards, Manu
am 29.12.2018 14:18
Hi Manu,
Thanks for your support. But this is impossible as I obtained the 200 Mbps before with the same computer PC.
Thanks,
Ahmad
am 29.12.2018 14:23
Also here is it
Intel(R) Ethernet Connection (2) I219-V
installed driver from Microsoft
4.5.2016
version: 12.15.22.6
am 31.12.2018 12:11
Hello Ahmad-Safwat,
Kind regards
