Moving to another city Kabel Internet
Sziszi
I would like to move to another address with my current contract by March 2020.
What are the procedures I should take ?
Grit
Hello Sziszi,
you should report the move to the moving service at least 14 days before the move date. The colleagues in the specialist department will process this and you will receive a letter stating whether you can install the connection at the new address yourself or whether a technician has to go out.
Regards
Grit
Grit
Hello Sziszi,
Regards
Grit
