Internet speed too slow
Eimantas
Good evening,
I have my Vodafone Cable Internet activated for 2 days. My plan is Cable Red 200. Unfortunately, the download speed is only around 95 Mbit/s using a cable connection to the router.
At the moment, I only use a foreign telephone number, therefore, I cannot call the technical service directly. Vodafone live chat refuses to help as well. Could you please help?
Best wishes,
Eimantas
EDIT: Moved to cable board. Boris
14 Antworten 14
Hi Tina,
My router is on again.
Best wishes,
Eimantas
Tina
Hello Eimantas,
you can now please perform some tests with our speedtest. Please via direct LAN connection.
Best regards
Tina
Hi Tina,
I did some additional tests but observed no change in my download speed.
Best wishes,
Eimantas
Tina
Hello Eimantas,
what speed was measured? Also around 100 mbit/s?
Can you please check the network settings of your hardware? Possibly a speed limit is set there.
Best regards
Tina
Hi Tina,
Yes, the speed was as before, around 94-95 Mbps. Ok, I will look into this.
Best wishes,
Eimantas
