Cancel Security package
RutujaDeshkar
Digitalisierer
Digitalisierer
Hello,
Could you please cancel the security package additional service for my cable internet, as I do not need it.
Thanks,
Hemant
Tina
Hello RutujaDeshkar,
I still have your customer data in front of me. I finished the security package at the end of the test period. You will receive the cancellation confirmation separately.
Best regards
Tina
5 Antworten 5
Tina
Best regards
Tina
Thanks a lot would that mean the security package will not be charged post the 2nd month of the bill?
Regards
Rutuja
Tina
yes, that's right.
Can I close your thread?
Best regards
Tina
Thank you for your support.
You may close the thread.
Regards
Rutuja
Stephan
Hi RutujaDeshkar,
okay then we'll close here.
Regards
Stephan
