[English] Intenet very slow 0.05mbps
Bozo111
Hello,
I am apologizing for not writing in German, my German still isn't very good.
I am user of kabel Deutschland last 6 months and everything was okey until last few days ago. Internet was starting to slow down a lot and them it would recover by itself or I just reboot router and then it was normal.
The biggest problem happened yesterday at night when he slow down to 0.05 mbps according to speedtest and now is unusable.
I am having router CH7466CE and my speed shoud be 200mbps down.
For troubleshooting I done this steps :
Try on multiple devices using wifi and ethernet, restart router, factory reset and I even changed cables connecting from the wall plug to router.
Nothing helped and speed is still the same 0.05 mbps.
What can I do next? I would already call someone but like I said my German skills aren't very good so I am afraid I wouldn't know to explain what is happening.
Thank you in advance for your help,
Mit freundlichen Grüßen,
Bozo
Manu
Hi Bozo,
we'll see if we can fix this. Be so kind and send me your name, address and customer number in a private message. I'll check the connection and get back to you.
Report here in the post when the PM is out.
Best Regards, Manu
