18.05.2020 15:44 - bearbeitet 18.05.2020 15:51
Hi there, I have a CH7466CE (from Kabeldeutchland) and I configured a port forwarding to reach port 9090 on my computer using its mac address but it won't work no matter the IP I use, I tried using the IPv6 of the WAN and the IPv6 of my computer.
Does anyone have tips on how to solve it?
PS: Accessing my IPv6:8080 shows up the modem login : smileysurprised: which got me surprised, at least I changed the password.
PS2: I tested using my mobile that also supports ipv6
am 22.05.2020 14:23
Hello Jayson,
Portforwarding is not possible with DS-Lite. The only thing that will help here is to put the device into bridge mode and to connect a separate router behind it.
Best regards
Moni
am 23.05.2020 23:49
I cannot find any bridge mode on it, how do I do it?
am 24.05.2020 09:21
@Moni_GK schrieb:Hello Jayson,
Best regards
Moni
Hello Moni,
afaik IPv6 Firewall configarations /opening are possible with the Compal.
@Jayson are you sure your computer has a pulic IPv6 and not only a link local address?
Regards Robert
am 24.05.2020 13:37
@RobertP I was able to access the router outside of my internet using the ipv6:8080 but still the port mapping using the mac address didn't work.
am 24.05.2020 13:56
@Jayson schrieb:@RobertP I was able to access the router outside of my internet using the ipv6:8080 but still the port mapping using the mac address didn't work.
your computer also need a public IPv6 to be reachable from outside.
have you enabled IPv6 on your pc and did you received a public IPv6 (not link local) from the router?
is the pc's IPv6 similar to the one you used successfully to access your router from outside or completly different?
Regards Robert
