2.4 GHz not broadcasting on EasyBox 904?
PGB
This is a possible solution not a query.
For the last 14 days my EasyBox would not broadcast the WLAN SSID on 2.4 GHz, so a couple of 2.4 GHz devices could not connect. The SSID was broadcast on 5 GHz and 5 GHz devices could connect.
After trying a factory reset to no avail, I set up the normal WLAN to 2.4 GHz, Channel 1, WPA2 and the Guest WLAN to 5.0 GHz, Auto, WAP + WAP2 (as suggested by the Vodofone videos). I also set the same password for both frequencies.There was still no SSID for 2.4 GHz, so I thought that the box was faulty.
Today I thought I would give it one more try before trying to get a new box.
I reset the password of the 2.4 GHz WLAN so that it was no longer the same as that of the 5 GHz WLAN and also reset the 2.4 GHz Channel to 6.
My EasyBox now broadcasts on 2.4 GHz as well!
I don't know which if the settings actually got the 2.4 GHz WLAN working, but maybe this information will help anyone else with the same problem.
Andre
Hey PGB,
thanks for your feedback - its very much appreciated
I've moved the thread into the correct board, so that other users could find it.
Best regards,
Andre
