HOTSPOT TICKET NOT WORKING
inguz
Good afternoon!
Excuse me for writing in English.
Just got the hotspot ticket for one day, the connection was working perfectly on my MacBook for a few minutes, but after inactivity time went offline. While reconnecting to the "Vodafone Hotspot" network pops up a page (hotspotshop.vodafone.de), after logging in I'm able to check my hotspot ticket which is still active, but the link to display the remaining time redirects me to the main hotspot.vodafone.de/portal page, but not connecting to the internet.
M.A.C. address remains the same as when buying the ticket.
How to solve this issue?  I bought the one day ticket to try the service before getting the monthly ticket, but It's impossible even to start surfing!
Thank you in advance
Stephan
Hi inguz,
thanks for your response. Good to read, that the ticket will be reimbursed.
I close this thread with this. If you have questions again, you can contact the community again.
Regards
Stephan
7 Antworten 7
Tina
Hello inguz,
are you also connected to a hotspot? Have you tested it at different hotspots?
Best regards
Tina
inguz
Yes I am connected, and I also have the IP address assigned for this network, so it works.
I also tested in a different hotspot, but same situation. I connect to the network, login page pops up, I do log in but it doesn't connect me to the internet, the only thing I can do is to surf my hotspot account or buy another thicket. And when I try to check the remaining time of my ticket it redirects me to the main page hotspotshop.vodafone.de, but "you are online" doesn't appear
I also restarted my laptop wifi settings, delete cookies, checked DHCP configuration but nothing works.
It seems to be a server failure, like it's not linking my laptop to my ticket or something. But it worked at the beginning! And the M.A.C. address is always the same so I don't know what must be the issue
I need this connection since I will stay in Germany for few more months and have to work from home, and there's no option to go to cafeteria or something now. It's really annoying.. 😞 just losing of money and lots of time
Captura de pantalla 2020-11-06 a las 10.10.28.pngCaptura de pantalla 2020-11-06 a las 10.10.58.pngCaptura de pantalla 2020-11-06 a las 10.11.32.png
Tina
Hello inguz,
did you buy the ticket also with your laptop or with another device?
Best regards
Tina
inguz
Yes, I bought it with my laptop. The M.A.C. address in the purchase invoice and my laptop is the same all the time
Tina
Hello inguz,
did you buy the ticket directly or did you have another voucher?
Best regards
Tina
inguz
I bought it directly. Anyway the customer service will make a refund for the ticket.
Stephan
Hi inguz,
Regards
Stephan
