13.05.2022 15:48 - bearbeitet 13.05.2022 15:50
I have set up my mailbox with 5500 code and recorded myself. I have also set up call forwarding with *67#.
However, when I switch my handy to Airplane mode and try to call it from another phone, no matter how I configure my mailbox, I always end up hearing the standard vodafone machine:
"vodafone teilnehmer ist jetzt nicht erreichbar"
later it says the same but in english and call ends.
I want such calls to reach my mailbox (voice mail) when I'm not available.
am 13.05.2022 16:47
Hello @Wurtz
Please try the following GSM code: **62*5500#Dial button. The 67 code you have chosen just sets up the redirection in the busy case. Good luck and greetings. Jioti
13.05.2022 16:27 - bearbeitet 13.05.2022 16:36
By the way these instructions seem to be outdated:
"1. Mailbox anrufen: Mit eigenem Handy 5500 wählen
2. Vom Hauptmenü aus folgende Tasten drücken: Mailbox einschalten: 2 7 1 Mailbox ausschalten: 2 7 2 3.
Bestätigen mit #: Die Ansage informiert, dass die Anrufumleitungen jetzt zur Mailbox ein- bzw. ausgeschaltet werden."
(source: it's what virtual assistant Tobi has just replied me)
I don't get any confirmation after typing 271#, it says here I should get one.
Also when I press buttons slowly I hear machine saying that I pressed false button ("falsche Taste"). I think number "7" is no longer assigned to any option.
am 13.05.2022 16:47
Hello @Wurtz
am 13.05.2022 16:59
Thank you Jioti, it helped!
It amazes me why such important code is not mentioned in instructions. Mailbox is pretty much useless without call redirection.
