am
11.01.2021
11:40
- zuletzt bearbeitet am
11.01.2021
12:36
von
pRo-Marco
Hello,
For the last days my current internet is really really really slow. I should have 1000MB but yup, normally i have half os the speed but later is even slower.
I use only the wireless connection.
I've test it against 4 machines, all macs, and some linux machine, and some tablets, speed is the same slow.
Account nummer: ***
Using this as checks: https://speedtest.vodafone.de/
and I have like ~ 10 Mb.
I did try to restart the modem, reset the modem, change the channels, use 5g, check the cable. same results.
Can someone have a look, or tell me the next steps.
regards,
C
EDIT @claudiug Please don't post proivate data public. Kind regards Marco
am 13.01.2021 10:04
Hello claudiug,
I would be happy to take a look at the line. Please send me a PN with your customer data (name, address, customer number and date of birth).
Please contact me again when you have sent me the data.
Best regards
Moni
am 13.01.2021 10:14
hello and thx for the reply.
I've send you a private message with the requested information.
regards
am 14.01.2021 10:59
Hello claudiug,
when exactly did you start having this problem? Is the connection via Ethernet just as slow?
Greetings Moni
am 14.01.2021 14:40
Hello,
I can only test via wireless, and for the last few weeks is getting slower and slower.
Either download or upload is absolutly slow. Maybe the router is broken.
i did the following
- reset router use default
- use the 5gz frequency
- use diff machines(macs, linux, tables, phones) all wireless
using this as referrence: https://speedtest.vodafone.de/ and fast.com same results. add some pics from some tests that i did
am 15.01.2021 13:34
Hello claudiug,
there are two mistakes on the line here.
One is too high a load. The expansion measures are already underway here. There is also an active interference signal on the line.
I have opened a ticket. You will be informed when the error is found.
Greetings Moni
am 15.01.2021 16:42
thx for the help. There is any deadline or timeline for this?
am 18.01.2021 20:08
Hello claudiug,
unfortunately, no fixed date is currently known for the utilization.
The interfering signal is currently not active, so your connection should work a bit better.
Best regards, Martin
am 18.01.2021 21:14
hello Martin,
Thx for the update, currently the speed is 24mb. so that is like 2% of my normal speed. I dont think is fair to pay ~70 euros per month.
am 21.01.2021 11:17
just to inform that today it looks better than usual 🙂
