Vodafone Kabel - Fritzbox6690 - DNS disruption detected
Stern1520
Dear All,
Since 2-3 days, I have been observing short interruptions on my connection. The Fritzbox 6690 event log shows that "DNS disruption detected; name resolution will now take place via public DNS servers." Due to that, the connection is lost for some 20-30 seconds then it is established again.  I have tried restarting the router, but it did not work. Could you please guide me how to fix this problem?
Kind regards
Stern1520
Hello together,
https://www.youtube.com/watch?v=hoZohK18k70
I have followed the tips on this video then the cable statistics were reset. Since then, there is no connection problem.
RobertP
problem is not DNS disruption
post your channel values
internet >> cable information >> channels
Stern1520
Hello together,
The thread has been marked as resolved. Then I'll close the thread here.
Best regards Kurt
