Tons of 2.X_CISCO_COM_KickAssocDevices messages
afberendsen
Cable communication network. Modme shows zillions of messages similar to the on ebelow. I donot have / use WiFi from Vodazone .. I have my own Access Point device (mesh netwiork) connected to my modem / router. Since those messages started showing in the logs, I cannot connect to many web sites from my WiFi devices. For example: www.apple.com , www.microsoft.com , www.hp.com . However, other websites are working very well ( www.cisco.com , www.oracle.com , www.aws.com )
Configuration Changed: Set Device.WiFi.AccessPoint.2.X_CISCO_COM_KickAssocDevices to true from CLIENTTOOL, old value is: false, result: Set successfully. Wi-fi
Hello afberendsen,
alright. As the error disappeared I will close this thread.
Regards
Hello afberendsen,
if you use WiFi with your own device only I assume the error doesn't come from our side. In which federal state do you live? Can you reach the websites via ethernet connection? Please make a Pingplotter measurement at the LAN1 port of our loan device and send the result here.
Kind regards,
It was just Vodafone incompetence. The problem solved by itself after a couple of days. Nothing changed on my side. Based on the amount of people with the same proble at the same time, Vodafone is clearly responsible for it.
Hello afberendsen,
Regards
