Set bridge mode
Alecs
Hello,
I would like to set my Vodafone router to bridge mode. I saw that this can be done from my account.
My question is...after I change the status to bridge mode on, the change is done automatically and immediately? I need to wait some minutes/hours/days?
I have read on the forum that is enough to connect WAN port from my personal router to LAN1 in Vodafone docsis.
After this it should work just fine.
If something is not working properly and I want to move back, it's enough to change again from my account? My old settings from DOCSIS will be still there?
Thanks a lot !!
Moni_GK
Hello Alecs,
You can set the bridge mode via your customer portal. The change is applied within a few minutes. Our router is then only a pure modem and all settings are then carried out on the router connected behind it. The settings in your own router will be kept.
Greetings Moni
