Received faulty router from Vodafone
Monali
Received faulty router( Vodafone station)  from Vodafone for cable internet connection  , the power  LED light is not coming up after plugging all required cables.
Please help to replace the faulty router at earliest
9 Antworten 9
RobertP
was macht denn die Power LED? blinkt sie?
wenn ja, ist nicht die Vodafone Station defekt, sondern es gibt ein Problem mit deinem Anschluss
kontaktiere den Support und melde dass die Selbstinstallation fehlgeschlagen ist
The vodafone station LED is not flushing at all , it seems the router is completely unresponsive.
We have checked the connection of powersocket, it is working fine with other appliances, only the vodafone station is dead.
andreasabaad
Auchmal den Schalter auf der Rückseite eingeschaltet?
Yes tried to on the back switch multiple times also tried the reset button option but nothing is working.kindly help to  get this replace.
dann kontaktiere den Support
https://forum.vodafone.de/t5/Vodafone-News/Dein-Kontakt-zu-Vodafone/m-p/1912292#M10954
Support in englisch bekommst du über WhatsApp
Already tried whatsapp in the shared number.
It did not help , ultimately routing to the digital assistant - TOBI and there is no resolution.
Can you please support to resolve this issue as soon as possible.
frage Tobi mehrfach nach einem Kundenbetreuer
hier befindest du dich in einem reinen Kunden helfen Kunden Forum
Monali
Thanks Robert for clarifying.
While I am trying to check with TOBI - digital assistant , Inhave additionally booked a service at local vodafone shop for help.
Do you have any idea if that cost me additional money for service by people at vodafone shop as this is completely a issue from Vodafone for a new customer ?
der Tausch des defekten Routers ist für dich kostenlos
