Unwetter: Was tun?
am 05.05.2024 15:53
Im trying to activate my fritzbox router 6690. I checked everything, it’s compatible. It’s the 2000 2965 art. It is connected with a lan cable, I did factory resets multiple times. I checked the ip address on myfritz and it starts with a 10. I’ve tried everything and don't know what to do.
am 05.05.2024 15:56
in which federal state of Germany do you live?
am 05.05.2024 15:56
am 05.05.2024 16:01
I live in Spiesen-Elversberg. So I believe it is Saarland
am 05.05.2024 16:08
I hit the solution button by accident and can’t get it to go back. I still need help please
am 05.05.2024 16:17
don't use external DNS server and disable DNS security in your browser
also disconnect all other devices from Fritzbox
am 05.05.2024 16:24
Ok Im using google chrome so I just turned off the dns settings. The only thing connected is the lan cable to the laptop. Im factory resetting it now to try again
am 05.05.2024 16:28
I turned it off, factory reset it and it still didnt work
am 05.05.2024 16:36
what happens if you try to reach activationportal?
am 05.05.2024 16:46
am 05.05.2024 17:00
@jj111 schrieb:I put my information in and then it says activation portal failed.
then no DNS problem 😉
but sometimes there is a timing problem
try. again
