am 13.07.2022 13:35
Hello,
I have just installed my new CableMax 1000 plan (for 1 Gbps) and follow the instructions. The Wi-fi network was correctly set up, and the internet also connected without any problem. However, the internet speed is consistently lower than 1 Mbps.
It is not Wi-fi interference as I have tested connecting the cmputer directly to the router via a LAN cable with the same results.
How can I resolve this?
thanks,
Jorge
am 13.07.2022 14:02
Hello @Kostrisch your Router still not unlocked to the Vodafone Services, that means still not registrated to Vodafone. Because of that you have only Speed of 1Mbit/s. You should call Customerservice of Vodafone, they will nudge the Registration Procedure. Alternatively you can wait here for a Moderator. But that will take some Days, because they worked at the Threads about they come in. Hope this will help a little bit. Greetings haegar2609
am 13.07.2022 14:02
am 14.07.2022 10:02
Hello Kostrisch,
I would be happy to help you. Which federal state do you come from?
Best regards
Nancy
14.07.2022 11:28 - bearbeitet 14.07.2022 11:29
Hallo Nancy, I'm in Köln, NRW.
am 20.07.2022 12:07
Hi Kostrisch,
I'm sorry to keep you waiting. We currently need a little more time to respond. ![]()
What is your current situation? Is your router now working without any problems? If not, please be so kind and send us a private message with the following data: Customer number, name, address, date of birth, state and current mobile phone number.
As soon as we have received your message, we will take care of your problem together.
Kind regards
R4mona
