Internet is not working
Mahdi2
Hello my internet connection is not working since this morning, I tried to go through the automatic support, it didn't work, I tried calling the support number, I can't understand a word it a robot that speaks only German, so I am stuck.
My internet led is blinking red all the time, I tried the reset, remove the cable and connect it again nothing is working.
Issue solved changed the cable and did a reset as recommended by the automatic support, 5 min uplug the modem and 15 min wait for the configuration.
Thanks for your time guy
6 Antworten 6
Torsten
Which medium do you use then - DSL or Internet via the TV cable connection?
I think it's cable I suppose it the Vodafone TG3442DE the device I have, still no connexion since yesterday and no support from Vodafone
Moni_GK
Hello Mahdi2,
in which state do you live?
Greetings Moni
I live in Lebenstedt Salzgitter in Niedersachsen.
Moni_GK
Hello Mahdi2,
so everything is working again? Can I lock then?
Greetings Moni
