Getting Only 300 Mbps on GigaZuhause 1000 Kabel Plan
apraj
Hi Vodafone Community,
I recently subscribed to the GigaZuhause 1000 Kabel internet plan, but I'm only getting a maximum of around 300 Mbps on my PC both via LAN and Wi-Fi.
I have already tested using a LAN cable (Cat 6) directly connected to the router, but the speed remains the same.
Could someone please help me understand why I'm not getting speeds closer to the 1000 Mbps that the plan promises? Are there any settings I should check, or could it be a technical issue?
Typ2000
Highspeed-Klicker
Highspeed-Klicker
Unfortunately this is a forum from customers to customers. No one will be able to help you right here.
Get in touch with the technical support.
2 Antworten 2
Post a screenshot of your router's signal levels.
Best regards Kurt
Typ2000
Highspeed-Klicker
Highspeed-Klicker
