am 23.03.2022 01:04
Hello!
Today in the afternoon wifi started to not work. I'm attaching an image, the router has the red light on internet since then.
A similar problem happened on 4th February 2022, it was due to interference you said. I don't know what's the problem now.
Rebooting didn't work, turning the router off and on didn't work.
I need help!
Also, it's not possible I have this kind of problem so often! May I have an explanation for it, please?
Thanks!
am 24.03.2022 15:06
Hi Airamaria,
we had a problem with the power supply and our technicians were able to fix it temporarily. You will receive an SMS from us when the error is finally fixed.
Regards
Wallace
am 24.03.2022 15:06
Hi Airamaria,
Regards
Wallace
am 25.03.2022 11:10
Thanks for the explanation! It is ok now.
am 27.03.2022 11:28
Hello Airamaria,
thank you for your feedback. We will close your contribution.
I'll also send you a PN right away with a survey about our service at this point. It would be great if you take a few minutes for it.
Regards Fred
